Statistics for raster - peculiar behaviour
973
09-17-2024 04:38 AM
nadja
I've noticed a peculiar behaviour with the statistics in ArcGIS Pro in rasters:
First: i create with gdal and gdalbuildvrt  and then gdal_translate cog tifs, which I then add to ArcGIS Pro to a map. I've got two ArcGIS Pro installations on two different computers creating a new vrt. If I open the created vrt in a text editor I see the statistics, with the correct value (e.g. 86). I verified this value in QGIS and with R.
If I add this vrt in to the map of my ArcGIS Pro instance A, the statistics are correctly displayed with a maximum of 86.
If I add this vrt to a map of my ArcGIS Pro instance B, the statistics are incorrectly displayed with a maximum of 64.
Any ideas why I get the wrong maximum displayed? And what do I need to change, to always get the correct value?
Since my instance A has some customisations, I compared the options >> Raster and Imagery. This didn't seem to change anything. Then I removed the folder under C:\Users\username\AppData\Roaming\Esri on my instance B and replaced it with the same folder of instance A. Then I got the correct value of 86 on A and B. Then I tried to localise the root of this issue and deleted and replaced the content of this folder in instance B. But now the result stayed correct. Which is great, but I still need to know why so that my colleages and I use always the correct settings when dealing with our rasters. Any hint would be greatly appreciated.
Alvis_D
same issue, how could I get the correct min-max range of a COG tif?
