Split polygon with line - doesn't work in ArcGIS Pro 2.3
7224
11
07-11-2019 01:57 AM
LearningAlaa
Please, I need help, I've been using ArcGIS Pro v. 2.3 for Digitizing buildings polygon feature class and When I use Tool called "Split" From Modify Features it still gives me the error in the image below "Split failed. New geometry must intersect polylines and intersect polygons in two or more places"
how can I use this tool in the same efficiency of use it inside ArcMap software?
Error in Modify a polygon feature
LaurenKiff1
I had a similar issue when trying to split a polyline into 2. I'd previously edited the dataset the day before, so have no issues with editing permissions. I ended up making a copy of the dataset, into the same fgdb, just with an '02' suffix, and I've been able to edit again. Strange, but I used that work around.
by Anonymous User
Not applicable
Make sure your toolbox is closed. I kept getting that error when my toolbox was opened
