Spatial Reference is not correct after changing data to new source in ArcGIS Pro
551
05-07-2019 11:56 AM
Joseph_Kinyon
Occasional Contributor II
In ArcGIS Pro 2.3.2, when I change the source the spatial reference does not change to the new source.
I was expecting the behavior to update to the spatial reference of the source.
Is this a lapse in updating or by design?
MelitaKennedy
Esri Notable Contributor
Hi Joseph,
Can you give me some more information? Let me make sure I understand the scenario too.
You have a layer in a map (or scene). You change the source data of the layer.
Are the two source datasets using the same data format (raster/tiff vector/file gdb feature class)? What is the data format? What are the details of the two spatial references?
Thank you,
Melita
AaronAbilez
Any one else having this issue ??? I have 2 feature classes in the same geodatabase and it still says that I have different spatial references after I have changed them to match each other??? Any suggestions?
