Hey all,
I have a shapefile of point locations and a polygon set provided in the form of a url (a web map). I add both layers to ArcGIS pro and they display and can be queried without any problems. The polygon layer contains three attributes as well as the object ID as a unique identifier.
I'm attempting to run the spatial join tool on these to determine what points fall inside what polygon. The result I would like is a new point layer with the attributes from the polygons joined to the points. When I run this I don't get an option to include the polygon object ID value. Also when I run the tool I get the three other polygon attributes (no objectID) with nulls for every value.
Is there limitations on performing analysis on web map layers? The only attribute I really want is the objectID but it doesn't show up in the list of attributes I'd like to join.
Any info would be greatly appreciated.
Thanks
JP
