Spatial join on ArcGIS PRO
922
08-02-2021 03:59 AM
cermichael13
Hello, im trying to use spatial join tool between polygon layer and point layer. In merge rule, i want to apply two rules on same field - like, sum and count for example. How can i do that?
right now, Only one rule can be applied on the chosen field.
Thank you.
JayantaPoddar
MVP Esteemed Contributor
Under Field Mapping > Add a new field. For that particular field, Add new source (use your original desired field here).
Think Location
JayantaPoddar
Think Location
cermichael13
It worked!
thank you
