Is it possible to sort features based on order attributes selection in ArcGIS Pro?
Thanks.
Solved! Go to Solution.
Select records in a table interactively—ArcGIS Pro | Documentation
seems no, unless you are adding a sequence number to a new field as you go
You'll probably need to be a little clearer on what you mean. It's possible to sort features by any number of attributes.
Are you referring to their order on the Attributes pane? That, I believe, is only based on the objectID, and does not follow the sorting defined in the table.
Ok, sorry. I selected my points in the following order (OBJECTID field): 1, 2, 5, 4 (see image). I need to have a table in the same order (1, 2, 5, 4) and not (1, 2, 4, 5). It's possible?
Thanks.
To make a sort stick, you need to use Sort (Data Management) - ArcGIS Pro | Documentation
What I need is to obtain a listing of my points according to my selection order. It's possible?
Thanks all.
Thanks all.
