Snappy, economical way to put latitude and longitude onto 20 Sample Addresses
598
03-08-2024 03:08 PM
Labels (3)
DanAllenhtn
I just added 20 addresses to an existing project in ArcGIS.  The addresses are in Excel.  To add them to the project, I clicked Add Data in ArcGIS, pointed to the excel fkile containing the spreadsheetwith the 20 sample addresses.  Now the 20 addresses are in the project
Robert_LeClair
Esri Esteemed Contributor
So your MS Excel file is read-only in ArcGIS Pro - as such, you cannot add an X and Y attribute field to your *.xlsx file.  To do this, you'll need to export the layer to a new Feature Class in your project file geodatabase.  Then you can run the Calculate Geometry Attributes (Data Management) GP tool to add the Lat/Long coordinates to your newly created feature class.
