Slightly corrupted view of polygon (multipolygon) from spatial MSSQL source
726
06-04-2021 03:02 AM
PärÅman
New Contributor II
The polygons journey: SHAPE -> FME (clipped) -> MSSQL Spatial
Viewing it in SQL Managment Studio (checking with STIsValid()):
Viewing it i ArcGIS PRO:
Converting GEOM.STAsText() in MS Mgmnt Studio and importing to layer i ArcGIS Pro using arcpy:
Has it to do with how ArcGIS Pro renders multipolygons from MSSQL, or is it that my data is corrupt?
DanPatterson
MVP Esteemed Contributor
how are holes oriented in your *.txt file? arcpy expects outer-rings oriented clockwise, inner-rings(holes) oriented counterclockwise
... sort of retired...
PärÅman
New Contributor II
Yes indeed, it seems that every polygon (inner and outer) is reversed. I'll try to correct it in the FME process step. Thank you!
