Show/Hide Annotations Based on Layout Name?
691
09-10-2021 10:44 AM
JamesWilcox1970
New Contributor III
I have a map of project areas that feeds several overlapping layouts. The project areas are irregular so sometimes the boundary of a layout cuts off portions of a project area, leaving seemingly discontinuous areas.  If I label the discontinuous areas individually so that they show on the one layout, the extra labels show up on the other layouts that show more of that project area.
Layout ALayout ALayout BLayout B
Is there a way to show or hide annotations based on the layout name? Or is this something that I would have to fix in post, using Adobe Illustrator to delete the extra labels?
David_Brooks
MVP Regular Contributor
@JamesWilcox1970  You could set up a Map Series with "page queries" on your annotation layers. That way you control which annotations are visible in each map shee
David
..Maps with no limits..
JamesWilcox1970
New Contributor III
@David_Brooks I will give that a try. Thanks!
