Show extent of one map in another map
4974
02-27-2015 11:49 AM
MichaelPolly
In ArcMap, you can show the geographic extent of one data frame in another data frame. So, for example, you can create a layout containing two data frames, the main map - and an inset overview map depicting a rectangle for the extent of the main map.
Can this be done in ArcGIS Pro?
In ArcPro, you can link maps so you can view the same extent of each map simultaneously. But, is there a way to mark the extent of one map in another map?
-Mike
Tags (1)
DavidBarnes
That functionality has not made it into ArcGIS Pro yet. It is on our todo list.
DavidBarnes
TimSexton1
This is now available in ArcGIS Pro 3.2+.  Here's a link to the article
