Service Area Settings
113
4 weeks ago
TierneyRosenstock
I need to do a service area analysis for drive time, but my data does not have a time unit in the attribute field. It does have length and speed limit, but I am unsure how to set up the travel mode for the network to conduct the analysis. Any input would be much appreciated.
DavidPike
MVP Notable Contributor
Do you have a Network Dataset built or can you obtain one for your area?
otherwise:
Cost attributes—ArcGIS Pro | Documentation
an example cost for car_drive_time could be:
time (hours) = length (km) / speed (km/h)
for a segment/edge 60km long and a speed limit of 120kph:
time = 60/120 = 0.5 hours
for truck_drive_time, the speed limit might be 60kph, so time = 1hr
TierneyRosenstock
I do have a network built for my area using our county road layer, but I don't know how to set up the travel modes and associated cost settings in the network dataset properties. I previously did a service area by distance for another analysis and it would not perform a calculation by miles. I had to use feet. I am working in mph. Here's the settings I have tried, but when I go to run the service area it still has ft under Mode in the travel settings group;
Screenshot 2025-04-25 080653.pngScreenshot 2025-04-25 080102.pngScreenshot 2025-04-25 080149.pngScreenshot 2025-04-25 080212.png
