I want to QA the address field in my table by removing records that don't have a street number anywhere in the cell. Because StreetMap Premium can use a street number that is not at the beginning of the cell, I still want to keep records in which the number is after the street name, so simply sorting or using "begins with" is not an option. I've tried selecting by using "has value(s)" and "doesn't have value(s)," but I keep getting 0 records selected. So for example, if the cell has
Smith Ave 226
how do I come up with a way to either select that record so I can invert the selection or select records that don't have any numbers?
Thanks.
Thanks for the suggestion. I didn't get a chance to check it out because I discovered that what I was doing wrong was using "does not include the value(s)," when I should have been using "does not contain the text" because the address field has both letters and numbers.
You can use several options
python - Check if a string contains a number - Stack Overflow
but you could try
a = 'Smith Ave 226'
# `a` is your field
any([i.isdigit() for i in a])
True
will give you records that have a number, either `not` the above or switch the selection
