Saving in ArcGIS Pro is very clunky
858
06-03-2019 01:39 PM
SUSANMYERS
Oldschool ArcGIS user... I find the ability to perform the various saves in ArcGIS Pro to be very CLUNKY.
If a change is made to an alias (whether to the current layer or the data source) of a field in the Fields view of the table, and then I go to close the Fields tab of that layer, I get "Unsaved Changes Found" asking me if I am sure I want to close the pane...that all unsaved edits to the workspace will be lost.  So, I try to find anywhere where the option to Save is not grayed out...  Not finding any. I guess I wish there were someplace in the program window where I could see a separate small panel overview summarizing the various unsaved edits with save buttons next to them so I could just click them and be done.  Ugh.
KoryKramer
Esri Community Moderator
The Save button will be grayed out for the Fields View if you have unsaved feature edits (in a map).
When you hover over that button, it will tell you that:
But we know it's been a source of frustration, so in Pro 2.4 there is an info banner which hopefully will help more:
SUSANMYERS
Thank you so much for your speedy reply.  InDesign has a neat feature where it constantly appraises the user of the "number of errors" and provides a quick access utility that lists each one and provides the direct ability to fix each one.  I could see this type of feature to make saves very helpful.
KoryKramer
Good input.  Thank you, Susan.
by Anonymous User
Not applicable
Fairly minor, but it would be good if there was also a warning if the field was being used by editor tracking (which prevents field editing/deletion and throws ERROR 002557, which can't be found) or other functions which restrict field updates/edits. Just one more thing users wouldn't have to check
