Run Module from Geoprocessing Pain or schedules Task Corrupts Table
447
02-08-2024 02:07 PM
JustinNettleton1
I have created a model in ArcGIS Pro that takes a csv document, exports the date using XY to points tool, deletes some fields then adds and calculates some fields.  When I run this model from the ArcPro model window below, it works just fine. No errors and the table populates just fine.
The end product I am looking for,  is to schedule the model to run several times a day to update this layer. I then have a different python script that update a web service in AGO. That portion works just fine. I just can't get the data to that point.
The issue I am having is when I try to run the model from the Geoprocessing tool or try to schedule, it to run in task scheduler, it corrupts the table and I get this error.  The model says it runs just fine, but get this image below when I try to open the table.
Any one have any ideas on why this would be happening or different ways to go about this?
I am using. ArcPro 3.1.3
Justin Nettleton
Bud
Esteemed Contributor
heheh. “Geoprocessing Pain.”
