Rounding and converting raster values
1364
16
07-27-2021 07:15 AM
BeckB
New Contributor III
Hello,
I'm using ArcGIS Pro 2.8.1. I have a raster layer whose values I would like to round and then convert into a corresponding value. For example, if the current value is 9.788, I would round that to 10 and convert that to 144. Is there a way to do this?
JayantaPoddar
MVP Esteemed Contributor
Had Dan not asked the (appropriate) question, and you answered, I could have never imagined your question was related to Dates.
Let me try putting it in a single expression
Expression:
16*((Con(("RASTER" - (RoundDown("RASTER"))== 0.5),RoundUp("RASTER"),RoundUp("RASTER" - 0.5)))-1)+1
Think Location
JayantaPoddar
A RoundUp() function of (Raster Value minus 0.5), inside a Con() function should work.
In the following example, The Raster Calculator is checking for the Round Value is equal to 10. If the argument is true it will return 144. Else it will return the original Raster Value.
Con((RoundUp("RASTER" - 0.5)==10),144,"RASTER")
If required, you could further add Con() condition in place of the False Value (Nested condition). The ultimate False Value, I am keeping as 0 in this example.
Con((RoundUp("RASTER" - 0.5)==10),144,(Con((RoundUp("RASTER" - 0.5)==11),169,0)))
Hope it helps.
Think Location
BeckB
New Contributor III
Hello,
Thank you so much for this! Could you please clarify why 0.5 is subtracted?
JayantaPoddar
Good Question.
I couldn't find a function to do a proper Round, i.e. RoundDown values from decimal values of .0 to .499... and RoundUp Values from .5 to .99...
So deducting a 0.5 will always given me a value, which if Rounded Up, gives you the desired value.
A few examples
9.569 : 9.569-0.5=9.069: RoundUp(9.069)=10
9.0: 9.0-0.5=8.5: RoundUp(8.5)=9
9.25: 9.25-0.5=8.75: RoundUp(8.75)=9
*Just realised
The only issue is with values ending with .5 decimals.
9.5: 9.5-0.5=9.0: RoundUp(9.0)=9 (But you want 10 in this case) :pensive_face:
Alternatively, you could add 0.5 and use RoundDown() function.
Think Location
BeckB
New Contributor III
That makes sense! What would your recommendation be in cases of 0.5 decimals?
JayantaPoddar
How about this? First run the following Expression in Raster Calculator.
Con(("RASTER" - (RoundDown("RASTER"))== 0.5),RoundUp("RASTER"),"RASTER")
 Use its output Raster as the input Raster of the expression in my first post. Like this
Con((RoundUp("NEWRASTER" - 0.5)==10),144,0)
You may choose to create a model in Model Builder, if this is a repetitive process.
I don't want to complicate the expression. That's why providing the solution in two steps.
Think Location
DanPatterson
Is this value the only one that you want to round?
What is the significance of rounding it to 10, then converting it to 144?
Are you trying to scale a raster's data to a new range?
... sort of retired...
BeckB
New Contributor III
There are multiple values I would like to round. In a nutshell, I have satellite data recorded in 16-day intervals, which are numbered 1-23. I want to convert these numbers to the Julian day of year (i.e. the 2nd timestep, currently labelled 2, would be converted to day 16). I need to round the numbers so I can identify which day of year it is closest to (i.e. if the value was 2.34, I would assign it to the second timestep, day 16). Please let me know if you need further clarification!
JayantaPoddar
Expression:
Think Location
BeckB
New Contributor III
Thank you both so much for catching this! JayanthaPoddar, could I ask again for you to clarify the purpose of subtracting 1?
