Revit in ArcGIS Pro (attributes)
944
08-06-2021 12:25 AM
Labels (2)
Jasonpang327
I have a revit file(.rvt) which has some hyperlink (URL) in the properties table. However, when the revit file is opened with ArcGIS Pro 2.8.1., the hyperlinks could not be transferred and seen in the attribute table in ArcGIS Pro. How could I fix this problem. Thank you very much!
DanPatterson
MVP Esteemed Contributor
did you convert it to a gdb?
Convert BIM data to a geodatabase—ArcGIS Pro | Documentation
... sort of retired...
Jasonpang327
Yes, I did convert it. However, the properties sets are still not available to show in ArcGIS Pro. Thanks.
