Hi
Can training samples (image classification) be reused in a different location from where it was captured?
The training samples are of two plant species and the procedure works well for the area the training was done in. The same species and age class will be searched in a similar area.
ArcGIS Pro 2.9 I do not have access to 'deep learning modules'.
Regards
Solved! Go to Solution.
Yes, you can use the training dataset which is created for place "a" and you want to apply on place "c". But deep learning module is mandatory. You require image analyst extemsion for arcgis pro 2.9.
Moved to Imagery and Remote Sensing Questions
