Return Last feature in a Feature Set
704
01-05-2022 11:30 AM
JimWilliams
I am looking to return the last feature in a feature set. I can do this with the first record in a feature set, but I am unsure how to return other features from the feature set. Like the second record in a feature set.
var manholes = FeatureSetByName($datastore, 'Nodes', ['IN_1_EL'], true)
var intersecting = Intersects($feature, manholes)
var count_check = Count(intersecting)
if (count_check > 0) {
    return first(intersecting).IN_1_EL
else {
    return $feature.Down_Inv
Anyone know how to access the second value in a feature set?
Regards,
Jim
jcarlson
Getting the last feature is as simple as reversing the featureset's sort order and taking the first value of that. Unless otherwise specified, your featureset will be sorted by objectID ascending, so the last value would be
First(OrderBy(intersecting, 'objectid desc'))
Getting a feature at position n can be trickier, but you can do it by combining the reverse sort method with Top. By taking the top n features and then reversing the sort order, the feature at position n will be returned.
First(OrderBy(Top(intersecting, 5), 'objectid desc')) // returns fifth feature in the set
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
