Retaining attachments while merging two records in the same feature class
1177
6
06-11-2021 10:28 AM
AlfredBaldenweck
MVP Regular Contributor
I have a feature layer (pretend it's buildings on a college campus) containing a record for each building.
Each building has one or two photos attached to it via Collector.
I want to merge the buildings by function (e.g. all the dorms, the engineering buildings) into a multipart polygon, and I want to retain the photos attached to each record once they are merged. (So if Dorm A has 3 photos and Dorm B has 2 photos, I want the combined "Dorm" record to have all 5 photos).
I tried testing it and the Merge tool in the editing toolbar threw out pictures for the other record.
I tried googling it and found these two articles, but they seem to  be geared at combining datasets, rather than working within a dataset.
Is there a way to do this cleanly?
Thanks!
Edit: This tool here:
Scott_Harris
@AlfredBaldenweck Oh I'm sorry, yes, it seems the workaround that I suggested would only be applicable if you have access to the attachments table (i.e. in a local GDB).
MicZatorsky_AEC
Did you try setting the Maintain Attachments Environment setting?  The Merge doco shows it as supported.
AlfredBaldenweck
That's for the Merge (Data Management) tool for use between different datasets.
I'm looking for Merge (Editing) for use inside a singular dataset. Thank you though!
Scott_Harris
Hi @AlfredBaldenweck
It's currently not possible to use the Merge (modify tool) and have all attachments carry over; however, the attachment table is editable, so you could manually update the attribute on the attachments that store the related record's ID.
AlfredBaldenweck
Thanks for the response.
Is it possible to do that in ArcGIS Pro with features hosted on AGOL, or can it only be done once a hosted feature has been exported to a gdb on desktop?
Thanks!
Scott_Harris
MicZatorsky_AEC
Append, then merge?
