Removed feature class can't be recreated and registered again
2094
09-08-2023 02:17 AM
AndersMark
Versions: ArcGIS PRO 3.1.0 & Postgres 14
I have a registered feature class in a Feature Dataset. It was first created & registered outside the FD and then dragged in. Then I remove it with ArcGIS PRO (AGP). After that I create the table again from PgAdmin (or another Sql editor).  When trying to register the table in AGP I got a message that says "Error 001050 Either  registered with database already or cannot open the dataset."
It isn't registered and it does exist. The symbol in front of the table name i AGP Catalog doesn't indicate that it is registrered. The table is at this point empty.
I tried this with a feature class that hasn't been part of a Feature Dataset and then the registration is no problem. Something happens when the feature class has been inside a Feature Dataset. I guess some stuff is not removed from the sde-schema but I can't find where it is.
Any clues on where to search?
George_Thompson
Esri Notable Contributor
You could look in the gdb_items / sde_table_registry / sde_layers tables to see if there is already an entry there. If there is, I would contract technical support and work with them on how to potentially remove it.
DO NOT manually delete the rows in the repository tables as it could have unintended consequences.
--- George T.
George_Thompson
--- George T.
AndersMark
Thanks! I thought I had checked all tables BUT I missed out gdb_items. There are records from previously removed tables in that one. It must be some kind of bug i guess.
I have seen this behaviour i ArcGIS 10.* and have manually removed those records without causing any problem in database. I will try the same here. If it doesn't work I can recreate the whole database.
Thanks again for a fast answer!
George_Thompson
Not sure why those records are in there once you delete the table. I would highly recommend reaching out to technical support to investigate.
--- George T.
AndersMark
I removed the entries in gdb_items manually and now registration of feature class is possible. I have mentioned the problem and also the solutionfor the Swedish ESRI-team . Hopefully they will investigate i further.
