Remove overlapping areas based on an attribute field
204
09-08-2020 01:35 PM
HaileyWright1
New Contributor II
Hello, I have a polygon layer that contains overlapping areas. I would like to remove the overlapping areas based on a comparison of the overlapping attribute fields. In this example, keep only the area with the most recent year. I know I can do this by setting a topology rule and editing each overlap individually, but I'm trying to wrap my head around a faster way using the overlay toolset. Thanks for any help!
JoshuaSharp-Heward
Hi Hailey,
Overlay tools (Union, Intersect etc.) can be run with a single input to find self-overlaps, which may very well help out with what you're trying to do!
How Intersect works—ArcGIS Pro | Documentation
How Union works—ArcGIS Pro | Documentation
I imagine in this case you would want to use Intersect! Worth running it and seeing what the output looks like.
JoshuaSharp-Heward
Hi Hailey,
HaileyWright1
New Contributor II
Thanks for the tip Joshua! The resulting Intersect allowed me to process the overlaps pretty quickly.
Hailey
JoshuaSharp-Heward
Glad that worked out Hailey! If you're happy with the answer mark this question as solved to close it off
