Good morning,
Has anyone else encountered this problem?
I've already found a workaround for this issue, but it's less than ideal.
Using the reclassify tool (Spatial Analyst), I was reclassing a raster that created from a polygon feature class.
The raster had a value in each cell within the polygon, and a NODATA everywhere else.
Using the reclass tool in ArcMap, to change these NODATA cells to have a real value, worked fine.
Using the reclass tool in ArcGIS Pro, however, using the same feature classes, failed when I did this, with this error:
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds. Failed to execute (Reclassify)
