"The network dataset was not updated"
1627
03-28-2024 06:08 PM
M1
Hello, everyone,
In the properties of a network dataset, when I define the characteristics and cost of a new travel mode that is not pre-defined by default, and I go to save, the following message appears: "The network dataset was not updated". If the network dataset is built, no travel mode is created. Has anyone had this problem?
Thank you
DanPatterson
MVP Esteemed Contributor
this might apply
Network dataset rebuild—ArcGIS Pro | Documentation
... sort of retired...
M1
Thank you
Robert_LeClair
Esri Esteemed Contributor
This sounds like ENH-000165385 - "Improve error messaging when making improper configurations to Costs in Network Dataset"
When using a Field Script Evaluator for a Cost in a Network Dataset, if you enter the Fields Alias instead of the Field Name, when you hit OK to close the Network Dataset Properties an error appears "The network dataset was not updated." Instead of providing this nondescript error, providing something that indicates the Field was not entered correctly, or the syntax of the expression was incorrect would be more helpful.
M1
Thank you
