"Make Query table" gives me "Table initialization error"
1389
06-09-2018 01:51 AM
Axelvon_Matern
Hi!
I am having a few problems with the geoprocessing tool "Make Query table". And I am not sure if is an expected issue, a bug or the cause of something I am doing wrong.
1. I run "Make Query Table" with two tables: "Building" and "UseType" and add the fields I need. It is "Completed successfully".
2. Get an "Table initialization error" when opening the "Quary table".
I dont understand what is happening here.
Axelvon_Matern
Thanks Dan. You answer somehow made me understand something was wrong in my Geoprocessing settings. And after som tinkering I found out that I need to generate a key field to make it work with a shape field. I am not sure why yet tho.
DanPatterson_Retired
Try opening and closing the application...
as suggested here
Table view errors—ArcGIS Pro | ArcGIS Desktop
Axelvon_Matern
yerkoleiva_rocuant
I am having the same issue. I am just trying to open and interrogate a very simple table with no more than 20 records but pro does not allow me to open and work on it.
Any help please.
Jake
