"Collapse Dual Lines To Centerline (Cartography)" not in ArcGIS Pro 3.3
1518
6
09-30-2024 03:43 PM
MonicaMoreno-Espinoza1
Does the "Collapse Dual Lines To Centerline (Cartography tool)" not exist in ArcGIS Pro 3.3? I didn't see it in the list of tools that are not available in ArcGIS Pro and I found it in the tool reference but not within ArcGIS Pro. It also doesn't come up in with ArcPy. Am I missing something?
Robert_LeClair
Esri Esteemed Contributor
Last year, there was an ENH-000159022 request to implement the Collapse Dual Lines to Centerline GP tool in ArcGIS Pro.  This was implemented at the ArcGIS Pro 3.3 release.  What release of ArcGIS Pro are you using?
DanPatterson
MVP Esteemed Contributor
... sort of retired...
Mine doesn't have it...What version are you using?
DanPatterson
ahhh, you need an advanced license...
Cartography toolbox licensing—ArcGIS Pro | Documentation
check the limitations by license type
Hmm, I should have the advanced license.
Robert_LeClair
Thank you!! Looks like this is the issue. Did not realize I wasn't on 3.3 release. I will submit a request to IT.
