"Automatically save edits" is disabled, but so are the 'Save' and 'Discard' button. And my edits are being saved
7943
25
05-01-2017 09:46 AM
AZendel
Am I missing something? I personally don't like the idea of edits being saved without me deliberately saving or discarding them.  What if I accidentally select 1000 features and hit the delete key when I only intend to delete one feature?  As you can see below, I've unchecked "Automatically save edits", but the 'Save' and 'Discard' buttons are disabled, so I can't use them.  If I close Pro and reopen it, my edits have persisted even though I never clicked save.  As you can see, I've also checked "Show dialog to confirm save/discard edits".  In this particular case, I was editing points features in an unversioned feature class stored in a SQL Express "Personal SDE" database.
It's been a while and I can't remember what these settings were 'out of the box'.  I think that "automatically save edits" and "Make newly added layers editable by default" so both be disabled when someone starts using pro for the first time.  I believe the latter is enabled by default. If so, that is very dangerous. I think every edit session should be very deliberate, especially when editing 'enterprise' data.
BrianBulla1
Yes, but I am using versioned data and I do not have the option to "Save".  Previous to 2.4.2 I have always been able to "Save" my edits, or not "Save" them and start over again.
Unless I am reading what Kory is saying incorrectly.....
DavidWheelock2
Wow!  Have you called tech support on that?
BrianBulla1
No, not yet.  Another thing I am noticing is that my edits cannot even be undone.  They are not showing up on the 'Undo Stack'.
BrianBulla1
OK, so it turns out that the layers in our SDE that I was editing were not actually versioned (although I thought they were).  So nothing to do with the latest 2.4.2 release.
Sorry for the confusion.
StefanieWenker
I just upgraded to ArcGIS Pro 2.8 and this is still an issue...
ZachBodenner
MVP Regular Contributor
Agree, this is something that needs to be fixed. I'm not a software engineer by any stretch but...why? Why is it difficult to have this behavior in Pro when it was standard in ArcMap?
