Query out features with blank fields in ArcGIS Pro?
4508
08-04-2020 12:43 PM
JuliaSurkis
New Contributor II
This seems like it should have an easy solution, but I can't for the life of me find it. I want to query out all features in a layer that do not have a value. I did not create the data, all the features already have their attributes filled in, and there is no "null" value in the blank field I want to query. If I try to just say FIELD is not null in the definition query, everything still shows up including all the features with blank FIELD.
ChrisChandler1
Hi, I believe I had the same problem with a text field in the table. I was able to make my query from the table using the "Select by Attribute" tool at the top of the table. In the Select by Attribute dialog I selected "Add Clause", and in that dialog selected my Attribute Field, the comparison value ("is equal to", "is not equal to", etc.), then click on the little slider button marked SQL. In the SQL dialog that comes up, the Clause comes in built except for the value you want to use. In this case where there is no value, I used two single quotes (ex. '' ,with no space). This selected the empty values in the field I was querying.
ElizabethWheeler
New Contributor III
This works for me.
dshap1211
out of curiousity i tried using the double single quotes, '' , for a definition query that was <field> is not equal to <''> - and that worked for me!
Thanks for the idea @ChrisChandler1
stormec
New Contributor II
I tried these steps, but errors. Tool must have been improved. Now, tool allows you to select "is null", apply, and OK. Then, I selected delete from above menu. Nulls removed. Nice and easy.😁
