Publishing A Map Service to Server Results in Unspecified Error
2152
7
10-25-2021 08:43 AM
by Anonymous User
Not applicable
When I try to publish a map service to our server, I get an unknown error (It just says error, no information or number). The analyzer also doesn't appear to run when i click analyze. Have tried on multiple projects and stripped back the file to a single layer to no avail. Any help is greatly appreciated.
I'm running ArcGIS Pro 2.8.3 but was happening on 2.8.1 as well (updated today).
by Anonymous User
Not applicable
Managed to fix this - while working through another error, my account was reset from "Publisher" role type to "Facilitator". Despite the fact Facilitator says it has publisher privileges, it seems that I am not permitted to publish a map service as a Facilitator. After updating my role type, restarting ArcGIS Pro and logging in and out, my issue was resolved.
JayantaPoddar
MVP Esteemed Contributor
Is it a standalone server? What is its version?
What type of layers are you using?
Please share screenshot of the parameters used while publishing.
Also screenshot of the error message.
Think Location
by Anonymous User
Not applicable
Thanks for your help. Yes, it's a standalone server and the version is 10.6.1. No one else on the team appears to have the same issue and permissions appear to be consistent.
Trying to upload shapefiles of boroughs in London.
Attached are the parameters, the results when I run the analyzer and the error when I click "Publish".
by Anonymous User
Not applicable
JayantaPoddar
Great.
Facilitator could be a custom role created by your organization, where Publisher role was edited, and some privileges (essential for publishing) might have been removed for finer control.
Think Location
by Anonymous User
Not applicable
Ah I see, yeah that sounds like it could be right. Thanks for your help!
ChrisTaylor2
New Contributor III
Hello,
I came across this thread when I encountered this same unspecified error, but it ended up being for a different reason and I thought it would be helpful to note it here.
My issue also presented when I was trying to publish to a standalone ArcGIS Server site, but ended up being because I had a trailing space in the site's connection name, just before the '.ags' extension. Once I corrected that I was able to publish, though in one test I had to restart Pro before it worked properly.
This occurred at ArcGIS 11.1, Pro 3.2 and 3.3.
jorisfrenkel
Occasional Contributor II
Thanks! I just had this same issue.
