Processing Seintinel-2 Level2a data in ArcGIS Pro Mosaic Dataset
1772
05-18-2018 02:12 AM
GeomaticsPublisher
New Contributor III
I'm trying to create a mosaic data from Sentinel2, Level 2A data in ArcGIS Pro, however I am getting an error: "2018-05-18T10:01:03.316: Error: 8004205f: No new mosaic dataset item was added" (see attached image) when adding rasters to the dataset.
According to the ESRI documentation ArcGIS supports Level 1c and 2a products: Satellite sensor raster types—ArcGIS Pro | ArcGIS Desktop
Data was downloaded from the scihub copernicus website: https://scihub.copernicus.eu/dhus/#/home
I have successfully managed to process the same Sentinel2 tile for a level 1c product downloaded from the same scihub website using the same mosaic dataset settings without any issues.
Has anyone else had success with creating a mosaic dataset from sentinel2, level 2a product downloaded from the scihub website?
Many Thanks
DanPatterson_Retired
it is a known bug
https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDA5NzEyMw==
with a workaround which you might understand given your situation
GeomaticsPublisher
New Contributor III
The link you provided forwards to a 404 page error. Can you update the link please,
thanks
fixed... it drops the == when pasting in geonet for some reason
EduardoMoller1
I can do it !!. I Create Dataset Mosaic for sentinel 2 using ARCGIS PRO but load data download from sentinel 2, the display is bad.
Using Arcmap y Arcgis pro is the same.
The dataset mosaic sentinel 2 have pyramids and statistics.
Thanks.
Eduardo from Chile.
