Problem with last step of Downscale Climate Data with Deep Learning
429
02-26-2020 08:01 AM
WilliamHarbert
Question from Downscale Climate Data with Deep Learning.    This course is going well, but I am having trouble with the rgdal install step in the jupyter notebook.    I have installed R both from scratch and let it be installed as part of the on-line course.  Everything worked until the Time Series Decomposition notebook.
Everything worked well until this step.  Earlier I had created the Regression model map time series successfully.
I do the process to begin jupyter-notebook using Chrome (as suggested) as the GUI.
If I use the default everything In the first code step of the notebook I get this error:
This occurs regardless of where R is located (both the local conda install and R install were successfully installed and binded)
or
Getting back to the error.  I can adjust the R statement in the notebook as follows with the result of an install:
Window continues...............
Success?  I'm not sure, but no errors eh?   Now for the question.  When I move down to calculate--everything read in are zeros!  You can see in this screen shot the result for R (all zeros), but in the background see the temperature_time_series are what was created in the tutorial--not zero!
I have the paths correct, but suspect that the error has something to do with the rgdal problem.
Any suggestions or helpful comments would be greatly appreciated!  Thank you!
WilliamHarbert
Hello,  I redid everything again and now running the final notebook I have the following for the installation step:
That's better!  I was careful to start with a clean installation from the default python clone,
Unfortunately I'm still getting no output from the analysis portions of the notebook--specifically I see the following:
Any thoughts would be greatly appreciated!
