Problem Sharing as a Web Layer from ArcGISPro to Portal hangs at "Uploading service Definition"
948
05-11-2021 10:50 AM
JoseSanchez
Occasional Contributor III
Hello everyone,
I am trying to share an sde feature class as a Web Layer in Portal from ArcGIs Pro.
I did the following set up to prepare the layer:
Versioned layer, added editor tracking and globalid field.
Right click layer and select Sharing as a Web Layer.
Versioning SDE connection Type: Branch
Reference Registered data: Map Image, Featured.
Configuration, Capabilities, Version Management checked.
Server and Folder:
- URL for Federated Server
- folder in Federated Server
Then after publishing it it stays hanging in this step:  "Uploading service Definition"
Please advise.
Thanks
jcarlson
MVP Esteemed Contributor
How long does it hang for? There are a number of factors that could slow down that part of the process. What is your Portal configuration like? Multiple machines? Cloud-based?
- Josh Carlson
Kendall County GIS
JoseSanchez
Hi jcarlson,
It stayed hanging for more than 10 minutes and I decided to stop the process.
We are using an enterprise Portal, that is server based, not cloud based.
How do I find more information about this Portal configuration?
 Thanks
MichaelVolz
Is this your first time using the right click Sharing as Web Layer procedure?  If not, is this the first time trying a branched versioned SDE feature class with editor tracking enabled?  I guess bottom line, what is different with this publishing process compared to your setup in the past?
JoseSanchez
Hi Michael,
This is the first time I am trying to publish a layer  using ArcGIsPro.
And yes I did branched versioned SDE feature class with editor tracking enabled.
