I recently created a new Pro project in a directory where I had been already working with some data in ArcMap. The directory was previously populated with a geodatabase before I created the Pro project. When I try to add data (either from the catalog pane or the add data button on the ribbon) from that existing gdb through the Project -> Folders or Projects -> Databases path, Pro does not recognize any content from the gdb. If I add the parent folder and then navigate to the gdb that way it recognizes all the contents of the gdb (screen grab below). I realize that's a pretty easy workaround, but it's annoying and I'd like to figure out why. Probably something simple I don't understand about the way 'Projects' work in Pro?....
Nevermind, problem solved. I'm a dummy....Pro had created a duplicate gdb with the same name in a subfolder and I was looking at different ones in Catalog. This thread can be deleted. Sorry.
