Pro 2.9.2 crashing when clicking on a symbol or opening the symbology window
115836
104
09-22-2022 01:45 PM
PiperMcKinnon1
Starting mid-day today all users in our organization are experiencing crashes of Pro 2.9.2 when we attempt any interaction with symbology, whether by clicking in the Contents pane or opening the Symbology pane. We have tried some fixes found in older posts and bug reports, including changing the rendering engine to OpenGL, clearing the display cache and running a repair, all to no avail. We will look into whether there have been OS or network changes next, but are wondering if anyone else is seeing this issue appear.
Leeloub
the .NET did not work for me. Is there a way to get help on this matter please?
RyanUthoff
@KoryKramer I am also having these issues, but I did not have any of those Windows Updates installed. However, uninstalling this Windows Update fixed the issue for me:  2022-10 Cumulative Update for .NET Framework 4.8 for Windows Server 2016 for x64 (KB5018515).
KoryKramer
Esri Community Moderator
Thank you, Ryan. We added that to the list of updates that causes this crash. The plan is for 2.9.5 to be available tomorrow - that will fix the crash without having to rollback the update. We are also planning 2.8 Patch 8 (2.8.8) to be available the first week of November containing a fix for this.
Thanks again for posting that specific KB.
Mary_BethDieter
2.9.5 fixed it for me, whew, that was stressing me out.
DirtDogRoj
I downloaded and installed SP 5 for ArcGIS Pro 2.9 today and now my symbology window doesn't crash.  Thank you!!
MatthewDriscoll
2.9.5 fixed it for me.
PatriciaJames
We are running ArcGIS Pro 2.9.2 on Server 2019 with .Net 4.8.03. KB5017263 caused maps to crash when symbology was changed. Removing KB5017263 fixed the issue.
PatriciaJames
We have since applied SP5 and it is working great!
SeanCarson
Possible workaround for those that need to wait until updates and/or upgrades can be applied...
  • Open ArcGIS Desktop
  • Add data to symbolize
  • Build custom symbology
  • Save as a layer file
  • Open ArcGIS Pro project
  • Add layer file
FrankSRazem
That is similar to our workaround. We symbolize it in ArcMap, save the mxd, then import the map into ArcPro 2.9.3 and the symbology is correct.
