Hello All,
We use a point feature class for our Highway Shield Locations. We use Label Backgrounds for the actual shield shape so we usually reduce the point symbology as small as it will go, turn off the outline, and set the fill color to None. We just started using them in Pro projects and are having a problem Selecting them when the Fill Color is None. If we set a color, then we can Select them. Is anyone else experiencing this?
