When export a PDF out of Arc, I can subsequently edit text elements in Acrobat:
The same imported map in Pro -> Export to PDF -> Attempt to edit any text element results in the following:
Is this by design?
This is finally fixed - yay!
Hi Michael,
What version are you using? I am using 2.6.2 and the issue does not seem to have been fixed.
I'm on 2.7, which is the version I think you need to get up to in order to solve the problem of editing PDFs.
Thank you! I'll check with our admins and see when we might be able to upgrade.
I am using 2.7.3 and I am still not able to Edit text in my PDF exports. What are the settings I need to export with in order for this to work. This is my last big hangup with PRO, I can't switch fully until this issue is resolved.
