Only display main polygon feature in map series
87
07-20-2020 09:13 AM
JuliaSurkis
New Contributor II
I have a rather large map series with a bunch of polygons showing different "clusters" of points. I would like each map series map to only have the main polygon for that page visible - some of the polygons overlap. Alternatively, how can I have the dynamic text showing the map name only show the desired polygon (right now I have it on "all visible rows," which works for some pages but not others since there are multiple polygons in the map view.
TomBole
HI Julia,
Applying a Page query—Layouts | Documentation to the polygon layer should display the polygon you want for each page. The Map Series group of dynamic text elements (Use dynamic text with map series—Layouts | Documentation) should give you options that you need.
Hope this helps,
Tom
TomBole
HI Julia,
Hope this helps,
Tom
