NoData Pixels in TIFF (DJI Terra Output)
455
06-18-2025 12:26 PM
SavannahThomson1
When I bring my TIFF output into ArcPro from DJI Terra, there are white spaces with NoData. If one band is missing data, it makes the whole pixel NoData. Is there a way to calculate each pixel where it won't be affected with one band not having data? I know the data is there as I can see it in DJI Terra and if I bring in each individual band the empty spaces will go away.
Robert_LeClair
Esri Esteemed Contributor
@SavannahThomson1 - do you have a sample TIFF I can work with to investigate this issue?  My email address is rleclair at esri dot com - thx!
RhettZufelt
MVP Notable Contributor
It almost looks like the symbology is messed up.  Are you actually using an Alpha layer?
Below is what mine shows by default when I add tiff to map.
I can get some weird results like that if I set an Alpha lyer.
R_
