Network analysis of green availability in urban areas (ARC GIS PRO)
1355
04-19-2021 03:46 AM
OndraVala
Hi everyone,
in university project, we are trying to find out how available are green areas for local inhabitants living in urban enviroment (center of Ostrava; about 40 000 residents).
- we deciced to choose network analysis - services area as the main tool to figure out
- cleaned open street maps paths shp in Ostrava center (from which we builed network dataset)
- created polygons with green areas
- created facilities (entries to green areas) - intersect of paths and green area polygons
Then we launched a service area analysis, which was designed to reveal which part of the area of ​​interest has access to greenery in 300 and 500 meters.
Problem is that this analysis doesnt seem to work right. Created buffers are odd and they do not seem to correspond to the selected distances. To the subject guarantor it also comes quite strange and quite different to what she was used in working with arc maps.
Comment for attached picture: Problem is that when I measure range of polygon (corresponding to certain facility - entry to green area) along the line its very different from what I entered as the service area calculation. Here is the example. I entered into services area calculation that i want to know area (along the line) which is 300 m away from facility, but it created polygon which coresponds to more than 400 m distance.
Does anyone have experience with this and could you advise us?
Have a pleasant day
DanPatterson
Were you using a projected coordinate system appropriate to your area?
Don't use Web Mercator if that was the one... it returns very poor results for anything involving distance and/or area measurements
... sort of retired...
DanPatterson
