Near tool not generating desired output-arcgis enterprise
439
06-20-2025 12:28 PM
GeorgeJonesRIGOV
hi all, i'm running a near tool and its giving null values all across the board.  I have the following parameters checked and this is the result that it gives me as seen below also. Any idea what i'm doing wrong? thanks GJnullValuesNearTool.pngparamsBest.png
DanPatterson
MVP Esteemed Contributor
and both are in the same projected coordinate system?
I would rule out anything at this stage by just letting it run without your distance specification and have a look at this to see other considerations
How proximity tools calculate distance—ArcGIS Pro | Documentation
... sort of retired...
DanPatterson
Near (Analysis)—ArcGIS Pro | Documentation
both are featurelayers or featureclasses?
GeorgeJonesRIGOV
Both are FCs. in different datasets
DanPatterson
