Multiple XML tags in arcade label expression
475
02-24-2021 01:06 AM
MathiasBerlin
I am trying to build a label expression with two fields where one field has a smaller font size and is top aligned relative to its bigger part. I've managed to change the font size between the two parts, but not combined with a vertical alignment.
My expression looks like this:
 "<v_align='top'>"+"<FNT size='5'>" + $feauture.Karttext_superscript + "</v_align>"+"</FNT>" + $feature.Karttext_base
I've tried different alignment tags but they don't seem to work combined with the font size tag.
Any ideas on how to make this work?
XanderBakker
Esri Esteemed Contributor
Hi @MathiasBerlin ,
In this help page you find a list of all the available tags to format labels in ArcGIS Pro: https://pro.arcgis.com/en/pro-app/latest/help/mapping/text/text-formatting-tags.htm
There is no vertical-align tag, however, you can get close by using this:
"<FNT size= '12'>" + "First Text" + "</FNT>" + "<FNT size= '9'> <SUP>" + "Second Text" + "</SUP></FNT>"
Make sure to switch off the option "Stack labels" in the label placement options, to avoid the text being wrapped and appear on multiple lines.
