Model from modelbuilder saves .atbx in personal space
294
6
3 weeks ago
MCTilma
Togheter with a co-worker, i work within an ArcGIS Pro project. In this project i made a model with modelbuilder. This .atbx is by default saved on my personal computer space (H:). So if my co-worker opens the ArcGIS Pro project, he does not see that model.
What can we do within the possibilities, that we can work with each others models. Is there a way to save it somehow in the ArcGIS Pro project, instead of the personal space?
With kind regards,
Matthijs
MCTilma
For now, we can use: save toolbox to version and save it with a path we both have access too. And then we can load the .atbx, however it is not the solution.
DanPatterson
Are you 'sharing' a project package?
Share a project package—ArcGIS Pro | Documentation
... sort of retired...
MCTilma
This seems like better solution then the workaround we have right now, thank you. This is however 'sort of retired'? but the functionality in ArcGIS Pro is still there in 3.4?
DanPatterson
'sort of retired'
my signature and status
Robert_LeClair
Esri Esteemed Contributor
Another option to consider via this Esri Support Services Knowledge Base article here.
MCTilma
This is indeed the workaround we have right now. but because we work on it multiple days, this workaround is a bit repetitive and does not feel like a permanent solution, but thnx for the reaction and article
