Merged existing layers with merge tool and tried to republish but lost all created_dates? Update: Apparently editor tracking is at fault?
1066
08-05-2019 08:43 PM
WilliamNguyen
Hi all, I merged multiple layers of the same data but split into financial years. I have been using collector to collect this data, but realised I need to combine all financial years into 1 layer to make reporting easier on the operations dashboard.
I merged all the financial year layers in Arcpro using the merge tool which showed everything perfectly including created dates in the attribute tables.
I then republished web layer to arcgis online (with Editor tracking and domains all filled in) but when I look at the layer in arcgis online and open an attribute table, all the created dates have been overridden with todays date? How do I keep the original dates from being overridden? I’m a bit shocked haha
Update: Apparently editor tracking is the culprit that is resetting all dates to the current day. Is there anyway around this?
KoryKramer
Esri Community Moderator
Hi William,
There is an enhancement request for this: [ENH-000088205: When publishing data from ArcMap to ArcGIS Online, allow for an option to not overwrite information about last edits.]
To get attached to that, you can contact technical support so that you can follow it.
WilliamNguyen
Thanks Kory for letting me know. I called tech support to attach my organisation to this. It s a bit frustrating that it seems to be a request that has been around for over 2 years.
Do you know if its at all possible to somehow combine all these past financial year layer with the current live layer so that I can report on them neatly onto one operations dashboard data source? Thats really my ultimate goal
