Matching an imported AutoCAD layer to other GIS shapefile layers
209
01-22-2021 05:42 PM
HIGISuser
Help!
I was finally able to figure out how to add an AutoCAD file to ArcMap. The AutoCAD data has a projection that is based on a specific near by point which I got from the NGS Data Sheet for that point.
I now have the False_Northing value, False_Easting and Scale Factor too. However, it is WAY off from any .shp I add for that region. When I try to change the projection the data disappears on my map.
I'd like to change the projection to WGS_1984_UTM_Zone_5N.
Can someone help!
AdrianWelsh
MVP Notable Contributor
Hi, dealing with coordinate systems and CAD data can be very tricky. Do you know a defined coordinate system for your CAD data? Or is it kind of arbitrary? If it is somewhat based off of a point, you can georeference the entire CAD drawing to fit on that point. Here is an article explaining how to do that in ArcMap
https://support.esri.com/en/technical-article/000012808
