MasterMap has grids built in. Any way to "ignore" those lines when using align tool
205
02-11-2025 06:33 AM
Maltuz
Hi
My first post.
The original maps I am using come with a built in grid lines.
When using the align tool, many times the align tool will go around a grid square and not the diagonal line through it. Zooming in better fixes this but the loading time takes a good while. Maps are between 2mb-875mb. Obviously this is reducing efficiency larger the map to zoom in and out in seconds
Is there a way to put in a command to ignore aligning to any "exact vertical or horizontal lines"?
None of the maps really have any lines that are perfect direction to the grid lines.
This would massively speed up the work and the align tool would become an even better god tool.
