Maplex Label Engine - How to apply Vertical and Horizontal Alignments to labels
1148
06-22-2022 04:16 PM
BigMaple
I am converting annotations brought over from CAD, and creating point feature classes with labels. I can replicate all most all of the annotation details, but the alignment piece.
The alignment options are disabled under the position section in the label class, so how can a label apply alignment values?
This is a must for the replacement of annotation with labels.
RobertBorchert
Honored Contributor
Just to verify. Are you looking under the Symbol tab or the Position Tab?
I assume you have an angle field that is an integer or double field you can reference.
You could try the rotate feature with arcade
Rotate($feature, <field>)
