Map Symbols for Airport legend ?
1534
10-05-2023 08:07 AM
DEAF_PROBERT_68
Honored Contributor
When you have an airport  layer and in the table shows me they have  a field column called Type.  It will tell you what kind of airport it is... such as international, miltary, Municipal, Regional.
So my question to people that work in airports industry or whoever, what is the national standard symbols for them to show in the Legend ?
I am trying to set it up that looks like here :
Thanks
KateDoughty1
I know this is from 2023 but just seeing it... in case it's still relevant...
It varies! If you're showing a large scale map with a legend such as your example, you could just use Esri airport icons, varying size by hub-size (I.E. International would be largest and most prominent). If it's a small scale map or focused on a specific airport, you can get more creative using a png icon based on the most common aircraft type operated there.
