I have a FC and two tables:
I've joined from Test_FC to Test_Table via the ID fields.
I've also joined from Test_FC to Test_Table_2 via the ID fields.
Result:
Question:
This is what the Layer Properties >> Joins window looks like:
To be honest, I don't really know what I'm looking at in that diagram. The structure presented there isn't what I expected to see; I would have expected something like this (but more elaborate):
Is that diagram presenting the joins correctly?
Thanks.
ArcGIS Pro 3.0.2
For my notes, Esri Canada support said this (case 03209739):
"Based on your workflow, the diagram does appear to be presenting correctly and I will try to break it down below:
