Make Feature Layer in Model builder produces 229 error
946
05-11-2022 10:49 AM
Labels (2)
kaww02
New Contributor III
I have model builder that runs find in ArcGIS with Iterate Row feeding into Make Feature Layer by a group number. When I run it in pro I get Error 229 because it says it can't open the Feature Layer (see attached error). I tried to compare my run in ArcGIS to the Pro results and the only thing I can see is where I created a grouping by Group Number in Arcgis it says "GP_Num #'" true and in Pro it says "GP_Num#" false - However it seems to pass through this section ok and the hang up is in the Make Feature Layer. Any thoughts?
kaww02
New Contributor III
For anyone that may need to know: The solution I have found was to change out Iterate Row to Iterate Feature
Robert_LeClair
Esri Notable Contributor
What release of ArcGIS Pro are you using?  Please advise.
kaww02
New Contributor III
2.7.2
kaww02
New Contributor III
2.7.2
kaww02
New Contributor III
