locked legend items
17789
44
02-10-2020 02:55 PM
DanAllison
New Contributor III
I have a ArcGIS Pro 2.5 map in which legend items (group layer name, layer name, etc.) are locked. They are checked but grayed out. See attached snips.
I have tried deleting the legend and creating a new one. I have tried creating a new layout. I have tried removing layers and re-importing them from the database. I have re-started the application. None of these has solved the issue.
TomBole
HI Branislav,
Have you made this comment in the Beta forum?
As to BUG-000128688 The Group layer name option in the Format Legend Item window is grayed out in ArcGIS Pro 2.5 if the layer is not the first in the table of contents. - this issue has been addressed for 2.6 and should be available with the Beta. Unfortunately, it appears that this is not being reflected in the release notes.  We will look into this.
Thanks for bringing this to our attention.
Tom
BranislavBlagojevic
Occasional Contributor II
Tom,
Thanks for question.
No! Only on the geonet.
Greeting!
KoryKramer
Esri Community Moderator
Hi Branislav - part of your agreement to participate in beta testing, is to use the Early Adopter Community (EAC) forums to report and discuss issues.  I'd encourage you to direct feedback about a beta version of the software to the EAC forum rather than GeoNet.
That said, from your post about the release notes, it isn't clear whether you have tested the functionality discussed on this thread, using Pro 2.6 beta.  If you have not, I'd encourage you to do so, as testing new/fixed functionality and providing feedback on said functionality through the EAC forum is the primary purpose of participating in the beta.  If you discover usability issues when testing the beta version, please provide that feedback directly in the forum, as product teams are monitoring those forums and make their best effort to assist in resolving issues. We appreciate your participation and your willingness to participate in ArcGIS Beta Programs, which helps Esri make better products.
Thank you!
ElizabethWheeler
New Contributor III
A different workaround is to select all those layers within the legend.show properties and the group layer name will toggle back for you to disable it.
Ness2
New Contributor III
Oh wow!  That actually worked.  Very simple and easy and more efficient than doing them individually.  Thank goodness - it was pretty frustrating not being able to make a nice, functional legend.
Arne_Gelfert
Occasional Contributor III
You're referring to this?
That selects all the entries in legend but doesn't undo they greyed out
BranislavBlagojevic
Kory,
Thanks for the note. YES! You're right about the EAC ... but it's just your response to @ Shayan Seyedi on May 11, 2020 in which you say "It looks like it will be fixed when 2.6 releases in a couple of months", as well as the post of Vanese Giles (see above) inspired me to write this on the forum where the discussion started (GeoNet) and where you, personally, invite users to report problems with ArcGIS Pro and where some explanations of these problems are actually expected.
Concerning the EAC, let me also praise the development team; they really try to solve problems! That is indisputable! However, many small things, such as this one named with "locked legend items" or with "setting up the attribute-driven color in symbology", etc. (essential in daily cartographic production), seem, in personal experience, to remain invisible to them. This is understandable, because new options and possibilities are predominantly discussed at the EAC forum and incomparably less existing problems - BUGS.
Regards.
KoryKramer
AmilynnAdams
New Contributor III
Soooo...this inability to select/de-select the group layer from displaying was a known bug nearly a year ago.  I've encountered the same thing now in Pro 2.7 and have been pulling my hair out until I found this post.  Is this going to be fixed anytime soon?
Patrick_G
I'm seeing this in version 2.8.2:
Mine's greying out the Headings checkbox. Single legend item, legend isn't locked, and I tried removing the layer from my legend and readding it - same result. Restarted Pro, nothing. I could try a new project file, but it's not an old project; I created this project last week.
Any feedback on this would be greatly appreciated. This is the first time I've seen this, and I'm a daily Pro user.
