list of mosaic dataset's rasters in arcgis pro
1048
5
03-17-2023 01:24 PM
AzinSharaf
How can I see the list of rasters in ArcGIS Pro participating in a mosaic dataset? ArcCatalog had this functionality.
Robert_LeClair
Esri Notable Contributor
There is a GP tool - Export Mosaic Dataset Paths (Data Management) that would generate a table of MDS data paths.  Would that work?
Robert_LeClair
Add the Mosaic Dataset to a Map View in ArcGIS Pro first, then right-click and open the attribute table.  In the table, you see a Name column that lists all the raster datasets participating in the MDS.
AzinSharaf
but it doesn't show the files path?
Robert_LeClair
AzinSharaf
thanks, that is what i needed. Is there any way to just see the list of rasters instead of exporting them into a file?
Robert_LeClair
Not to my knowledge but there is an ArcGIS Idea posted here you can upvote on so it gets visibility with the ArcGIS Pro Dev Team.
